As of 1.7.0 this is still true.
As a quick fix you can go in text mode, copy a quadratic curve (for water heater) and modify the values, including the name and handle. Open the .osm file with a text editor and search for OS:Curve.
For the handle, as it has been already discussed on this thread Creating handles for OSM objects, instead of changing a number or too it is best to generate a new version 4 UUID (for example here)
As Good question, as of 1.7.0 this is still true.
as well. As a quick fix you can go in text mode, copy a quadratic curve (for water heater) and modify the values, including values (including the name and handle. Open the .osm file with a text editor and search for handle)OS:Curve.
