If I understand your question, you want to import a floorplan into SketchUp to use as a guide to layout spaces and thermal zones? The OpenStudio plugin for SketchUp does not recognize SketchUp objects until they are migrated into an OpenStudio object (such as a space, shading surface group, or intertior partition group). Therefore you need to first create a new space, double-click to edit the space, then paste the floorplan into that space.
