Yes, include an Output:Variable for each output you want.
You can include the object Output:VariableDictionary and after a successful run, you will find a file eplusout.rdd that includes every variable that applies to your specific model. The IDF Editor will also parse this file automatically to help prepopulate choices for any Output:Variable.
You can also refer to the I/O reference guide, every object (or almost) has an input section defining what each fields are, and also an Output section related to the Output:Variable that apply to the object and what they mean if needed to explain.
Here's the one for ZoneHVAC:IdealLoadsAirSystem
