You can use the LoadProfile:Plant object to feed a scheduled load and flow rate to the plant. The schedule can be a year of measured or simulated data.
LoadProfile:Plant,
Used to simulate a scheduled plant loop demand profile. Load and flow rate are
specified using schedules. Positive values are heating loads, and negative values are
cooling loads. The actual load met is dependent on the performance of the supply
loop components.
