Calibrating a TRNSYS simulation is no different than calibrating a simulation with any software. You need to compare your outputs to your measured data (or in your case the CBECS average data). Based on the differences between the measured and simulated data you adjust your model parameters and inputs until the agreement improves. There are many standards, books, and papers that cover this process.
