The example file you mention shows how it's done, take a better look at it.
What these nodes should be will depend on the 'Fan Placement' you picked in ZoneHVAC:WindowAirConditioner
(cf I/O Reference Guide)
This input field has two choices: BlowThrough or DrawThrough. The first choice stands for “blow through fan”. This means that the unit consists of an outdoor air mixer followed by a fan followed by a DX coil. The fan “blows through” the DX coil
So assuming a blow through situation, the ZoneHVAC:WindowAirConditioner
's Air Inlet Node Name
should be the Return Air Stream Node Name
of the OutdoorAirMixer
object that's referenced (which is also the Zone Return Air Node...). The Air Outlet Node Name
should the the outlet node of the DX Cooling Coil
that is used.
In a Drawthrough situation, yourZoneHVAC:WindowAirConditioner
looks exactly like this drawing, except the heating coil doesn't exist:
The ZoneHVAC:WindowAirConditioner
object that's referenced (which is also the Zone Return Air Node...), like above.
should the the outlet node of the Fan
that is used.
