Copied from jack_l's comment, just to have an answer on the record: "Did you have a look at jEPlus+EA? It's a tool where you input a jEPlus parametric model and it performs multi-objective optimization through Genetic Algorithm. You just need to define your objectives in the rvx file, then launch the jEPlus project in jEPlus+EA. If your solution space is limited, you also have the option to run all jobs in jEPlus and then perform the multi-objective optimization manually as a post-process."
