There is not a prototypical building for growing facilities. You could emulate one by using the Warehouse prototype model and then increasing lighting levels to match a growing environment. You may also need to lower the default zone occupant activity level depending on the agricultural product.
There is not a prototypical building for growing facilities. You could emulate one by using the Warehouse prototype model and then increasing lighting levels to match a growing environment. You may also need to lower the default zone occupant activity level depending on the agricultural product.level.
