I would encourage you to reach out to the C.D.S. support team for your future questions. You can reach us at CDSHelp@trane.com or call us at 608-787-3926. We will be able to answer these questions for you more quickly by taking this approach.
The report that you are referring to is an Entered Values report. The fields that you have highlighted are specified in the Internal and Airflow Loads Library for the specific library member that you have applied to your model. I would suggest that you use the F1 Help documentation in the program to understand how these inputs affect your model.
