Top[] and Bottom[] are parameters defined somewhere earlier in the file. The brackets are part of EP-Macro. You should see somewhere ##set1 Top "some parameter" and ##set1 Bottom "some other parameter".
Top[] and Bottom[] are parameters defined somewhere earlier in the file. The brackets are part of EP-Macro. You should see somewhere ##set1 Top "some parameter" parameter" and ##set1 Bottom "some other parameter".parameter.
