Options are:
1) Use fewer output variables
DView has to load and render each output variable and meter from your simulation. If you are are say, exporting out temperatures from every surface in a large model, you are trying to import MBs of data and it will be slow to render.
2) Use a different viewer that can handle large datasets
There are better tools for viewing large .sql datasets. Tableau is the obvious one that comes to mind. Others can comment below with other suggestions.
