For the desing days you open the weater data in IDF Editor and in SizingPeriod:DesignDay you can see a list of the potentional SummerDesingDays and WinterDesingDays. Usually use the ones with the maximum/minimum (or the second ones) to size your heating and cooling capacity. Now for the solar radiation you can run your simulation and select the summary report from the output section. There you can see the values per month about solar radiation in the sections about outdoor enviroment.
