can you please share how you overcame this? I've tried outputting STDOUT to temp file and using RVU on it. I get octree error. (while the same oconv through prompt creates a functioning file).
I noticed that default output is UTF-8 and that the file is 10% larger than the prompt one, so I output it to ANSI; and its similar in size to prompt one, but still RVU can not open the file.
next thing to try is to save the binary stream directly... but I thought about asking for advice here first.
