There might be an easier way, but you could do this via an EMS program. Add a sensor for the ideal system airflow rate, calculate the fan power, and then actuate an ElectricEquipment object's power. The ElectricEquipment object can model both fan energy and heat gain.
There might be an easier way, but you could do this via an EMS program. Add a sensor for the ideal system airflow rate, airflow, calculate the fan power, and then actuate an ElectricEquipment object's fan power. The ElectricEquipment object can model both fan energy and heat gain.
There might be an easier way, but you could do this via an EMS program. Add a sensor for the ideal system airflow, calculate the fan power, and then actuate an ElectricEquipment object's fan power. object. The ElectricEquipment object can model both fan energy and heat gain.
