It sounds like you need to define a Construction:InternalSource and assign it as the construction of your zone floor surfaces. OpenStudio looks for surfaces with that kind of construction to create the surface group that the radiant system connects to, and having an empty surface group would cause your first severe error.
This answer has a bit more info on that.
