Openstudio is good for 3D modeling and some standard HVAC equipment simulation.
For advanced HVAC or refrigeration systems, you need to go to the EnergyPlus itself.
As for the refrigeration system, there is specific category in EnergyPlus called Refrigeration. Your wallin frezzer can be defined by Refrigeration:Case object.
As for the refrigeration system, there is specific category in EnergyPlus called Refrigeration. Your wallin frezzer can be defined by 'Refrigeration:Case' object.Refrigeration:Case
