Could you use the reviewer's logic as a response? Ask them to support their comment with a reference. Since 90.1 doesn't explicitly state that the baseline should match the proposed their position is just as credible as yours.
I set the baseline VAV terminal control to single max/min prior to the availability of OpenStudio Standards' baseline automation, which sets the VAV dampers to Reverse acting (dual maximum). The reason is not well documented in the OS Standards code, but perhaps @aparker can elaborate.
https://github.com/NREL/openstudio-standards/blob/49626ee957db63129bb74cfe08b48abd571de759/lib/openstudio-standards/standards/Standards.AirLoopHVAC.rb#L2290-L2297
Prior to OpenStudio Standards, I set the baseline VAV terminal control to single max/min prior to the availability of OpenStudio Standards' baseline automation, max/min. However, now I use OS Standards, which sets the VAV dampers to Reverse acting (dual maximum). The maximum) although the reason is not well documented in the OS Standards code, but perhaps code. Perhaps @aparker can elaborate.
Prior to OpenStudio Standards, I set the baseline VAV terminal control to single max/min. However, now I use OS Standards, which sets the VAV dampers to Reverse acting (dual maximum) although the reason is not well documented in the OS Standards code. Perhaps @aparker @asparker can elaborate.
Prior to OpenStudio Standards, I set the baseline VAV terminal control to single max/min. However, now I use OS Standards, which sets the VAV dampers to Reverse acting (dual maximum) although the reason is not well documented in the OS Standards code. Perhaps @asparker @aspark2 can elaborate.
