I'm not sure why the SU script isn't working, but will your workflow/project allow you to work in OpenStudio instead? If so, I would suggest the Add Remove Or Replace Windows using the Apply Measure Now feature. It will apply the WWR across all exterior surfaces on a given facade which will save time if the model has several spaces.
I'm not sure why the SU script isn't working, but will your workflow/project allow you to work in OpenStudio instead? If so, I would suggest the Add Remove Or Replace WindowsSet Window To Wall Ratio By Facade measure using the Apply Measure Now feature. It will apply the WWR across all exterior surfaces on a given facade which will save time if the model has several spaces.
Here's a measure to Add Remove Or Replace Windows By Facade that might be helpful in the future.
I'm not sure why the SU script isn't working, but will your workflow/project allow you to work in OpenStudio instead? If so, I would suggest the Set Window To Wall Ratio By Facade measure using the Apply Measure Now feature. It will apply the WWR across all exterior surfaces on a given facade which will save time if the model has several spaces.
Here's a measure to Add Remove Or Replace Windows By Facade that might be helpful in the future.helpful.
Here's I also have a measure to Add Remove Or Replace Windows By Facade that might I can share if that would be helpful.
I also have a measure to Add Remove Or Replace Windows By Facade that I can share if that would be helpful.
