If you are in Canada and are doing LEED under the M/NECB code
EE4 does support this kind of work in a similar manner for MNECB 1997.
CAN-Quest (The Canadian version of eQuest) will support this for NECB 2011. The beta is out if you contact NRCan's OEE Janet.Hudy@NRCan-RNCan.gc.ca for this. It is still under development.
As Matt has mentioned above. There is similar work to create the NECB 2011 standards into OpenStudio that is currently in development / proposal stage.
As Matt has mentioned mention above. There is similar work to create the NECB 2011 standards into OpenStudio that is currently in development / proposal stage.
