We've done a quick test exporting the IDF to run in the same EnergyPlus version used by DesignBuilder and weren't able to reproduce the problem. We did, however, get the same problem when trying to use the converted IDF in E+ v9.1 (not yet supported by DesignBuilder). I would suggest that you import the IDF into the same version of EnergyPlus as you have in the version of DesignBuilder that you're using. If that doesn't fix the problem you should ask DesignBuilder's support team to review your model, assuming you have a licence.
