I suggest converting your IDF library to epJSON format to allow it to be used from an OpenStudio measure.
- On a windows machine, first add the path to your
energyplus.exefile to your system path (e.g. C:\EnergyPlusV9-1-0). - Open a terminal from the directory where the IDF library is.
energyplus -c my_awesome_idf_library.idf
Then, you'll be able to load the epJSON file in an OpenStudio measure and retrieve the data from it using standard associative array (Ruby Hash) syntax.
energyplus.exefileinstallation to your system path (e.g. C:\EnergyPlusV9-1-0). - Open a terminal from the directory where the IDF library is.
energyplus.exeinstallation to your system path (e.g. C:\EnergyPlusV9-1-0). - Open a terminal from the directory where the IDF library is.
Then, you'll be able to load the epJSON json file in an OpenStudio measure and retrieve the data from it using standard associative array (Ruby Hash) syntax.
Then, you'll be able to load the json file in an OpenStudio measure and retrieve the data from it using standard associative array (Ruby Hash) syntax.
