I would start by making some hourly reports for the system heating variables to try and track down why your heating energy is so low. Is the system cycling on for heating? Does the loop just not have enough heat because the boiler isn't turning on? Maybe that will at least give you some direction. You could also reference the underlying code in the old DOE2.1E Engineer's Manual. http://doe2.com/download/doe-21e/
