Yes -- you can use 4 PlantLoop objects to represent the loops in your diagram. Even though some components are not listed in the Plant Application Guide that you mention. I would recommend using an interface (OpenStudio, DesignBuilder, etc.) to build these loops and have it connect the components because connecting inlet/outlet nodes by manually editing the IDF input file would take longer and likely have some errors to debug.
