When going through error reports, start at the top and fix the first one, then rerun the model, as most times many of the errors further down will be solved by the ones near the top. Warnings wont cause process termination, but may lead to other errors and very often to incorrect results.
I don't know the tutorial, but in this case, it appears that the error report pretty much tells you what to do. - If you are autosizing anything on the Plant side, the first Warning is relevant. - For the Furnace Severe error, take a look at the InputOutputReference and/or the EngineeringReference in the Documentation folder and do a search for that Furnace type to see what settings are valid for the Scedule, for example.
This general process for solving failures usually works pretty well.
