The WindowProperty:ShadingControl object was renamed to WindowShadingControl, but has almost all of the same input fields as before. Since this alters a specific window construction, you no longer need to reference the window shading control in the FenestrationSurface:Detailed object, as you pointed out. As a result, this input field has been removed from the FenestrationSurface:Detailed object. You can read more about the latest set of input fields for EnergyPlus v9.1 of the WindowShadingControl object here and read more about all of the IDD changes caused by this update here.
