You would place the heating coil in the outdoor air system equipment list. Not all coil types are allowed. For example, a DX coil would need to be wrapped in a CoilSystem object. Coils in the outdoor air system are always set point based control, meaning that a set point manager is used to place a temperature set point at the coil outlet node.
AirLoopHVAC:OutdoorAirSystem,
OA Sys 1, !- Name
OA Sys 1 Controllers, !- Controller List Name
OA Sys 1 Equipment, !- Outdoor Air Equipment List Name
VAV Sys 1 Avail List; !- Availability Manager List Name
AirLoopHVAC:OutdoorAirSystem:EquipmentList,
OA Sys 1 Equipment, !- Name
Coil:Heating:Electric, !- Component 1 Object Type
My OA Heating Coil, !- Component 1 Name
OutdoorAir:Mixer, !- Component 2 Object Type
OA Mixing Box 1; !- Component 2 Name
Valid coil types in the outdoor air system:
Coil:Heating:Fuel
Coil:Heating:Steam
Coil:Heating:Water
Coil:Cooling:Water
Coil:Cooling:Water:DetailedGeometry
CoilSystem:Cooling:Water:HeatexchangerAssisted
CoilSystem:Cooling:DX
CoilSystem:Heating:DX
CoilSystem:UserDefined
Valid non-coil types in the outdoor air system:
OutdoorAir:Mixer
Fan:SystemModel
Fan:ComponentModel
Fan:VariableVolume (scheduled for deprication after V9.2)
Fan:ConstantVolume (scheduled for deprication after V9.2)
AirLoopHVAC:UnitarySystem
HeatExchanger:AirToAir:FlatPlate
HeatExchanger:AirToAir:SensibleAndLatent
HeatExchanger:Desiccant:BalancedFlow
Dehumidifier:Desiccant:NoFans
Humidifier:Steam:Electric
SolarCollector:UnglazedTranspired
SolarCollector:FlatPlate:PhotovoltaicThermal
EvaporativeCooler:Direct:CelDekPad
EvaporativeCooler:Indirect:CelDekPad
EvaporativeCooler:Indirect:WetCoil
EvaporativeCooler:Indirect:ResearchSpecial
OA Sys 1, !- Name
Coil:Heating:Fuel
Coil:Heating:Steam
Coil:Heating:Water
Coil:Cooling:Water
system:
OutdoorAir:Mixer
Fan:SystemModel
Fan:ComponentModel
EvaporativeCooler:Indirect:ResearchSpecial You would place the heating coil in the outdoor air system equipment list. Not all coil types are allowed. For example, a DX coil would need to be wrapped in a CoilSystem object. Coils in the outdoor air system are always set point based control, meaning that a set point manager is used to place a temperature set point at the coil outlet node.
OA Sys 1, !- Name
Coil:Heating:Fuel
Coil:Heating:Steam
Coil:Heating:Water
Coil:Cooling:Water
Valid non-coil types in the outdoor air system: OutdoorAir:Mixer Fan:SystemModel Fan:ComponentModel Fan:VariableVolume (scheduled for deprication after V9.2) Fan:ConstantVolume (scheduled for deprication after V9.2) AirLoopHVAC:UnitarySystem HeatExchanger:AirToAir:FlatPlate HeatExchanger:AirToAir:SensibleAndLatent HeatExchanger:Desiccant:BalancedFlow Dehumidifier:Desiccant:NoFans Humidifier:Steam:Electric SolarCollector:UnglazedTranspired SolarCollector:FlatPlate:PhotovoltaicThermal EvaporativeCooler:Direct:CelDekPad EvaporativeCooler:Indirect:CelDekPad EvaporativeCooler:Indirect:WetCoil EvaporativeCooler:Indirect:ResearchSpecial
You would place the heating coil in the outdoor air system equipment list. Not all coil types are allowed. For example, a DX coil would need to be wrapped in a CoilSystem object. Coils in the outdoor air system are always set point based control, meaning that a set point manager is used to place a temperature set point at the coil outlet node.object.
OA Sys 1, !- Name
Coil:Heating:Fuel
Coil:Heating:Steam
Coil:Heating:Water
Coil:Cooling:Water
OA Sys 1, !- Name
ZoneHVAC:OutdoorAirUnit:EquipmentList,
\memo Equipment list for components in a ZoneHVAC:OutdoorAirUnit. Components are simulated
\memo sequentially in the order given in the equipment list.
A1 , \field Name
\required-field
\type alpha
\reference OutdoorAirUnitEquipmentLists
A2 , \field Component 1 Object Type
\type choice
\key Coil:Heating:Electric
\key Coil:Heating:Fuel
\key Coil:Heating:Steam
\key Coil:Heating:Water
\key Coil:Cooling:Water
\key Coil:Cooling:Water:DetailedGeometry
\key CoilSystem:Cooling:Water:HeatexchangerAssisted
\key CoilSystem:Cooling:DX
\key CoilSystem:Heating:DX
\key HeatExchanger:AirToAir:FlatPlate
\key HeatExchanger:AirToAir:SensibleAndLatent
\key Dehumidifier:Desiccant:NoFans
\key AirLoopHVAC:UnitarySystem
A3 , \field Component 1 Name
OA Sys 1, !- Name
A1 , \field Name
\required-field
\type alpha
\type choice
