To do it programmatically, you could either use OpenStudio and Ruby or EnergyPlus and Python.
OpenStudio and Ruby
Import the IDF to OpenStudio and as @luis lara suggested run a Ruby script (or formal OpenStudio Measure) on the OpenStudio model.
Here's a lightly tested Python script (using eppy). Depending on your model, you may want to add filters (e.g. Construction:InternalSource, Material:NoMass, etc.).
import os
from eppy.modeleditor import IDF
idd_dir = r'C:\EnergyPlusV9-1-0'
idd_file = r'Energy+.idd'
idd_path = os.path.join(idd_dir, idd_file)
idf_dir = r'C:\WORK\18151 DEN Level 4\18151-Baseline\run'
idf_file = r'in.idf'
idf_path = os.path.join(idf_dir, idf_file)
IDF.setiddname(idd_path)
idf = IDF(idf_path)
total_heat_capacity = 0
surfaces = idf.idfobjects['BuildingSurface:Detailed'.upper()]
# loop through the surfaces to calculate heat capacity
for surface in surfaces:
construction_heat_capacity = 0
construction = idf.getobject('CONSTRUCTION', surface.Construction_Name)
# get the field names, which in eppy is a list of
# ['key', 'Name', 'Outside_Layer', 'Layer_2', ... 'Layer_10']
construction_field_names = construction.fieldnames
# loop through the construction's field names (layers),
# skipping first and second (key and Name)
for field_name in construction_field_names[2:]:
# get the material object from the layer
attribute = field_name
material_name = getattr(construction, attribute)
material = idf.getobject('MATERIAL', material_name)
# calculate the material's heat capacity and add it to the construction's
if material is not None:
thickness = material.Thickness
density = material.Density
specific_heat = material.Specific_Heat
material_heat_capacity = thickness * density * specific_heat
construction_heat_capacity += material_heat_capacity
# add the construction's total heat capacity to the model's total
total_heat_capacity += construction_heat_capacity
print('J/m2*K =', total_heat_capacity)
References from OpenStudio
OpenStudio and Ruby
import os
idf = IDF(idf_path)
OpenStudio and Ruby
Import the IDF to OpenStudio and as @luis lara suggested run a Ruby script (or formal OpenStudio Measure) on the OpenStudio model.model
Here's a lightly tested Python script (using eppy). ) for EnergyPlus. Depending on your model, you may want to add filters (e.g. Construction:InternalSource, Material:NoMass, etc.).
import os
idf = IDF(idf_path)
# get the field names, which is a list of
OpenStudio and Ruby
Here's a lightly tested Python script (using eppy) for EnergyPlus. Depending on your model, you may want to add filters (e.g. Construction:InternalSource, Material:NoMass, etc.).
import os
idf = IDF(idf_path)
import os
idf = IDF(idf_path)
