Update. It turns out I can get rid of the real constant icon and redefine this term as something like valve.opening = 0.5 in the equation section.
Update. It turns out I can get rid of the real constant icon and redefine this term as something like valve.opening = 0.5 in the equation section.section. This does yield an answer but the mass flow rate plotted does not give a range of data like it did before which is problematic. Perhaps because it is not time-varying?
