@Mamak if you have an IDF file with compact schedules, you can import that into OpenStudio to save them as OpenStudio compact schedules. You can then load that a library under the file menu to drag compact schedules into other OSM models that you are working on.
If you are writing measures, you can also create compact schedules using the API based on user inputs or external files.
