As far as I know OpenStudio 2.8.0 should be compatible with SketchUp 2018. However, it hasn't been tested extensively, please post a bug report if you find an issue. SketchUp 2019 upgraded to Ruby 2.5.1 and will not be compatible with any OpenStudio versions in the 2.x series. The OpenStudio 3.x series will be compatible with SketchUp 2019. A timeline for OpenStudio 3.x series is available here. Please note that the OpenStudio SketchUp Plug-in will be distributed and maintained separately from OpenStudio 3.x according to the OpenStudio Application separation plan.
