You could try "SetpointManager:ReturnTemperature:HotWater. This object tries to achieve a specific return temperature on a plant loop, but given a min and max range. This is essentially a load-based reset because the greater the load the higher the setpoint will be in order for the return water to stay the same temperature. I havn't used this object like this before, but it's worth a try.
