I may have a workaround for this, but would like an expert opinion.
I changed the single inner shading surface into two surfaces so they shared edges with another surface.
BEGIN ORIGINAL
BuildingSurface:Detailed,
    Inside Shelf,            !- Name
    WALL,                    !- Surface Type
    Shelf,                   !- Construction Name
    Daylit Zone,             !- Zone Name
    Surface,                 !- Outside Boundary Condition
    Inside Shelf,            !- Outside Boundary Condition Object
    NoSun,                   !- Sun Exposure
    NoWind,                  !- Wind Exposure
    0.0,                     !- View Factor to Ground
    4,                       !- Number of Vertices
    1.0,                     !- Vertex 1 X-coordinate {m}
    0.0,                     !- Vertex 1 Y-coordinate {m}
    2.0,                     !- Vertex 1 Z-coordinate {m}
    4.0,                     !- Vertex 2 X-coordinate {m}
    0.0,                     !- Vertex 2 Y-coordinate {m}
    2.0,                     !- Vertex 2 Z-coordinate {m}
    4.0,                     !- Vertex 3 X-coordinate {m}
    1.0,                     !- Vertex 3 Y-coordinate {m}
    2.0,                     !- Vertex 3 Z-coordinate {m}
    1.0,                     !- Vertex 4 X-coordinate {m}
    1.0,                     !- Vertex 4 Y-coordinate {m}
    2.0;                     !- Vertex 4 Z-coordinate {m}
END ORIGINAL
BEGIN MODIFIED
    Inside Shelf Top,        !- Name
    Wall,                    !- Surface Type
    Inside Shelf Bottom,     !- Outside Boundary Condition Object
    Inside Shelf Bottom,     !- Name
    Inside Shelf Top,        !- Outside Boundary Condition Object
    1.0,                     !- Vertex 2 X-coordinate {m}
    1.0,                     !- Vertex 2 Y-coordinate {m}
    4.0,                     !- Vertex 4 X-coordinate {m}
    0.0,                     !- Vertex 4 Y-coordinate {m}
END MODIFIED
I removed the inside shelf from the DaylightingDevice:Shelf
BEGIN ORIGINAL
DaylightingDevice:Shelf,
    Shelf,                   !- Name
    Daylit Upper Window,     !- Window Name
    Inside Shelf,            !- Inside Shelf Name
    Outside Shelf,           !- Outside Shelf Name
    Shelf;                   !- Outside Shelf Construction Name
END ORIGINAL
BEGIN MODIFIED
    Shelf,                   !- Name
END MODIFIED
These changes got rid of my Zone="DAYLIT ZONE" is not fully enclosed Warning, while only making these two warnings.
**Warning** GetSurfaceData: CAUTION -- Interzone surfaces are usually in different zones
**  ~~~  ** Surface=INSIDE SHELF TOP, Zone=DAYLIT ZONE
**  ~~~  ** Surface=INSIDE SHELF BOTTOM, Zone=DAYLIT ZONE
**Warning** GetSurfaceData: InterZone Surface Azimuths do not match as expected.
**  ~~~  **   Azimuth=90.0, Tilt=0.0, in Surface=INSIDE SHELF TOP, Zone=DAYLIT ZONE
**  ~~~  **   Azimuth=180.0, Tilt=180.0, in Surface=INSIDE SHELF BOTTOM, Zone=DAYLIT ZONE
**  ~~~  ** ..surface class of first surface=Wall
**  ~~~  ** ..surface class of second surface=Wall
What I don't know is if this kluge actually works as the Light Shelf is supposed to. The exterior shelf should perform the same since the DaylightingDevice:Shelf works whether or not there is an interior light shelf. The interior light shelf is still a surface, light is shining through the top window, hitting the inner light shelf, which should reflect into the space like EnergyPlus does with any light shining through a window and hitting a surface.
I will accept this answer if I can get some confirmation from a developer that my inner shelf hack will model correctly.
BEGIN ORIGINAL
END ORIGINAL
BEGIN MODIFIED
END MODIFIED
BEGIN ORIGINAL
    Shelf,                   !- Name
END ORIGINAL
BEGIN MODIFIED
    Shelf,                   !- Name
END MODIFIED
**Warning**    ** Warning ** GetSurfaceData: CAUTION -- Interzone surfaces are usually in different zones
**Warning**    ** Warning ** GetSurfaceData: InterZone Surface Azimuths do not match as expected.
