I typically see fan-powered boxes serving perimeter zones to augment higher heating/cooling loads. Using a series terminal unit allows you to reduce the amount of static on your central AHU (0.2" w.g. instead of 0.5" w.g.).
Here's some literature from Titus that summarizes their advantages
