Your HouseModel is expecting a vector of doubles. Currently it is a String. I hence suggest to do the following:
Change
valueto be a Vector by changing the curly brackets to square brackets:value = [out, 20]Use the
ExpressionToTokenactor from the BCVTB library to convert that String to a vector of doubles. TheExpressionToTokenis in theConversionspackage of the BCVTB library.
You will need to configure the output ofExpressionToTokento be a vector of doubles. You can do it by right clicking on the actor selectingCustomize->Portsand by setting theTypeof the output Ports to be[double]. This type should be compatible with the input of your HouseModel.
Change
You will need to configure the output ofExpressionToTokento be a vector of doubles. You can do it by right clicking on the actor -> selectingCustomize ->CustomizePortsand by setting theType of the output Ports to beType[double]. This type should be compatible with the input of your HouseModel.
Change
ExpressionToTokenactor from the BCVTB library to convert that String to a vector of doubles.TheTheExpressionToTokenis in theConversionspackage of the BCVTB library.
You will need to configure the output ofExpressionToTokento be a vector of doubles. You can do it by right clicking on the actor -> selecting Customize -> Ports and by setting the Type of the output Ports to be[double]. This type should be compatible with the input ofyouryourHouseModel.
