You could build up a model and assign ideal loads systems to each zone. This would tell you the heating and cooling loads associated with the indoor conditions you specify.
You could build up a model and assign ideal loads systems to each zone. This would tell you the heating and cooling loads associated with the whatever indoor conditions you specify.
