It would probably be best to isolate just the geometry and save it as a separate idf file to edit within Euclid. The only difference in the geometry objects between v8.7 and v9.0 is the Shading Control Name field in the Fenestration object, which was removed in v9.0. You could add this field in, open it in Euclid to make changes, then either use the idf updater or remove the Shading Control Name field for compatibility with v9.0.
