I didn't run your example but you wrote that you didn't use the ExternalInterface in the IDF. Looking at the IDF, I couldn't find any external interface objects. Consequently there is no data exchange between the BCVTB and your EnergyPlus model. I suggest to read the documentation of the BCVTB which explains why you need external interface objects and how you need to set them up for co-simulation.
