See Santosh's answer as that seems like the best way of doing this using EPPY.
This can also be done easily using Modelkit. I just published a demo video on this exact problem.
You would just need to modify your IDF file so that it has no Design Day objects. Then your root file would be just a couple lines, inserting your IDF file and the location parameter. Check out the video, and the subsequent video on rakefiles, and let me know if you have any questions.
See Santosh's answer as that seems like the best I'm not aware of a simple way of doing this using EPPY.
This EPPY, however, this can also easily be done easily using Modelkit. I just published a demo video on this exact problem.
