You can use the setThermostatTolerance method to change the thermostatTolerance parameter.
You can refer to the SDK for more details on the available methods for a given class here.
As for how to call an object, you can, for example, create an array with all of the available objects of a certain class that exists in your model. If you want to get all the AvailabilityManagerNightCycle objects in your model, you could define the run method to do
array = model.getAvailabilityManagerNightCycles
Note that you need to use the name of the classes in the Openstudio SDK, not the name displayed in the GUI or the name in the Energyplus I/O reference.
As for how to call an object, you can, for example, create an array with all of the available objects of a certain class that exists in your model. type. If you want to get all the AvailabilityManagerNightCycle objects in your model, you could define the run method to do
As for how to call an object, you can, for example, create an array with all of the available objects of a certain type. If you want to get all the AvailabilityManagerNightCycle objects in your model, you could define the run method to do
