I'm not quite sure if that would work but what I would try to do is, update the air properties and atmospheric pressures of the weather file you are using to reflect the change in altitude.
I'm not quite sure if that would work but what I would try to do is, update the air properties and atmospheric pressures pressure data of the weather file you are using to reflect the change in altitude.
