You might try using the min/max schedules in the outdoor air controller to replicate your schedule. Use a fractional schedule (OA flow / Max OA flow) to determine the flow rate needed then use this schedules name for both the min and max schedule name inputs.
Controller:OutdoorAir,
A12, \field Minimum Fraction of Outdoor Air Schedule Name
\type object-list
\object-list ScheduleNames
\note schedule values multiply the design/mixed air flow rate
A13, \field Maximum Fraction of Outdoor Air Schedule Name
\type object-list
