Hi,
You are correct.
Have a look on Chapters 5, 6 & 19 of the Engineering Reference.
If you want to see the details of the EnergyPlus simulation, you can download the source and check the files (e.g. Photovoltaics.cc, Photovoltaics.hh, PhotovoltaicThermalCollectors.cc, etc). You can download the files directly from the github repository (../src/EnergyPlus/<'the-files>).
If you want to use Radiance, you can use an External Interface module, OpenStudio, BCVTB, run a script from command-line, etc.
Hi,
You are correct.
If you want to use Radiance, you can use an External Interface module, OpenStudio, BCVTBBCBTV, run a script from command-line, etc.
