Here's what I've found. Rather than using ZoneHVACEquipmentList, if you call zone.equipment, you get a vector of objects of class ModelObject, which can then be 'converted' to the specific equipment object you want with something like (for a fan coil):
zones = model.getThermalZones
zones.each do |zone|
zone_eqp = zone.equipment
zone_eqp.each do |eqp|
if eqp.to_ZoneHVACFourPipeFanCoil.is_initialized
fcu = eqp.to_ZoneHVACFourPipeFanCoil.get
end
end
end
From there, calling fcu.coolingCoil again returns a ModelObject, which can be converted to the correct object class by again checking if the class is initialized, then using "to_[class name].get", so ccoil = coil.to_CoilCoolingWater.get. The obvious downside is you have to know what equipment types you'll have in the zones ahead of time, or include logic for all available zone equipment.
To make changes based on space type or name, you'd just include logic within zones.each do |zone| to get the associated spaces (zone.spaces) and do your check before moving on to the equipment loop.
end
end
end
To make changes based on space type or name, you'd just include logic within for each zone to get the associated spaces (zones.each do |zone| zone.spaces) and do your check before moving on to the equipment loop.
Here's what I've found. Rather than using ZoneHVACEquipmentList, if f you call zone.equipment, you get a vector of objects of class ModelObject, which can then be 'converted' to the specific equipment object you want with something like (for a fan coil):
end
end
end
To make changes based on space type or name, you'd just include logic for each zone to get the associated spaces (zone.spaces) and do your check before moving on to the equipment loop.
