Hi there.
There is really only one other company that uses shell geometry, and that is IES. I could take a look at the file for you and see if I could write a script to construct the shell geometry and space boundaries.
You might want to ask this company if they will accept geometry for the shell geometry and space boundary that is identical (zero thickness walls) because everything generated by SketchUp and OS is a very thin planar wall.
