Hi, This playlist form the NREL youtube chanel help me alot when I start using OS.
https://www.youtube.com/playlist?list=PLPk2tlcZM0gyG3HLiblSjeKn6o1NPuPjO
Most of the time I autosize my system first and do a couple of engineer checks to make sure that my people,lightning,equipment, schedules etc... have some consistent values; then after i run my model on the HVAC Systems TAB and then on the right side of the UI (user inerface) when you select a piece of equipment you could edit and imput the values that you need.
I hope this helps you.
