The water heaters can also be used as storage tanks. Both the WaterHeater:Mixed and WaterHeater:Stratified have 2 sets of inlet/outlet nodes. The flow through these nodes will be used to calculate the resulting tank temperature.
WaterHeater:Mixed,
 A14, \field Use Side Inlet Node Name
 A15, \field Use Side Outlet Node Name
 A16, \field Source Side Inlet Node Name
 A17, \field Source Side Outlet Node Name
WaterHeater:Stratified,
 A16, \field Use Side Inlet Node Name
 A17, \field Use Side Outlet Node Name
 A18, \field Source Side Inlet Node Name
 A19, \field Source Side Outlet Node Name
