VRF terminal units can be connected to a DOAS using the AirTerminal:SingleDuct:Mixer
object. See the EnergyPlus example file DOAToVRF.idf. When modeling any HVAC system it is recommended that the manufacturers data be used to create inputs, including the performance curves when used. If unsure of how to create VRF performance curves see Creating Performance Curves for VRF Heat Pumps in Energyplus.
