"peopleperSpaceFloorArea" will return a value if the definition has a value for this field, but otherwise the optional will be empty. Putting it in an if statement protects against the ruby error if the optional is empty.
if peopleDefinition.peopleperSpaceFloorArea.is_initialized
peopleDefinition.peopleperSpaceFloorArea.get
end
"getPeoplePerFloorArea" will return a value regardless of which input field use used for the definition, but you do have to pass it the floor to use of the calculation.
peopleDefinition.getPeoplePerFloorArea(area)
Use the link provided in @Eric Ringold's answer for more options for this definition.
end
"getPeoplePerFloorArea" will return a value regardless of which input field use used for the definition, but you do have to pass it the floor are to use of the calculation.
"peopleperSpaceFloorArea" "peopleperSpaceFloorArea." will return a value if the definition has a value for this field, but otherwise the optional will be empty. Putting it in an if statement protects against the ruby error if the optional is empty.
end
"getPeoplePerFloorArea" will return a value regardless of which input field use used for the definition, but you do have to pass it the are to use of the calculation.
"peopleperSpaceFloorArea." This will return a value if the definition has a value for this field, but otherwise the optional will be empty. Putting it in an if statement protects against the ruby error if the optional is empty.
end
"getPeoplePerFloorArea" This will return a value regardless of which input field use used for the definition, but you do have to pass it the are to use of the calculation.
end
empty.
