I found a way of doing it. Just add another plant using a differnt source of enegy then it will be reported in ECB and LEED report. Though some explannation is needed to clarify to the reviewer. Also, assigning the humidification coil to a different plant will give you option to find the energy use in Equipment Energy Cosumption Report. Though they are not directly reported in LEED summary or ECB report.
