Hi Eric, yes, the sender warning is benign. The custom BSDF file is likely not being handled properly yet. I got your email, very cool that you are making your own mods to the measure! Sounds like you are halfway there. Most likely cause here is your custom BSDF is not getting placed in the model's support directory in time for it to be copied to the workflow.
UPDATE (3-6-19): Based on our discussion offline, please try adding the current working directory (with a '.') in your RAYPATH, and let us know how that works out.
UPDATE (3-6-19):
Hi Eric, yes, the sender warning is benign. The custom BSDF file is likely not being handled properly yet. I got your email, very cool that you are making your own mods to the measure! Sounds like you are halfway there. Most likely cause here is your custom BSDF is not getting placed in the model's support directory in time for it to be copied to the workflow.workflow. I haven't read your email in full but perhaps you could share the broad strokes here and we could get to the bottom of it publicly so others may benefit?
